Home › Forum › Ask A Member › Mark 28 issues
Viewing 10 posts - 21 through 30 (of 32 total)
  • #47180
    wedgie
      Thanks for the encouragement. I always figure if you guys can do it barehanded then so can I. But then again there’s always that 10 year old that can solve a rubics cube in under a minute.I still cant do it after 30 + years.
      I am coming up with a simple jig to hold the block still and support the crank so I can keep both hands free to poke the rings home . On the lookout for a couple of pieces of hardwood.
      #47186
      wedgie
        Now to find some hardwood scraps. 😉
        #47194
        wedgie
          Yay !
          Thanks everyone for putting me on the right track. I found I had to jiggle and wiggle the piston "just-so" to get the rings to work themselves into the bore. No way to do that without the jig to hold most of the weight.
          So now is a good time to ask about the correct orientation of the bottom crank seals. Both facing like this?
          IMG_20161108_154459.jpg[/attachment]
          20mercman
            Glad to see you got them in. Like I said, my confidence was high! 😉 The 26-16977 is the replacement seal. They are double lip seals. I can’t tell from your photo if these are double seals or not. I always install those as original with the open end of the seal facing the retainer, so in other words the other way. Your old seals will have witness marks on them from the retainer.
            Steve
            #47202
            wedgie
              Glad I asked Steve. Thanks. I will have a close look and see if they are double seals.
              #47214
                Seal lips face down.
                #49659
                wedgie
                  quote BillW:
                  Thank you Bill , and thanks to everyone, it’s back together with a few dollars in parts from Joe Poole. I used permatex anaerobic flange sealant. I shimmed the gearcase by feel, so I hope I got it right. Now that it’s running I will have to follow up on the starter recoil.
                  http://vid61.photobucket.com/albums/h57 … jzqurp.mp4
                  #49680
                    That motor sounds great Wedgie! How long since it last ran and how did you like the sealer?
                    #49681
                    david-bartlett
                      Very nice. I have a Mark 10 that I will be starting on soon. Very cool motors.
                      #49705
                      wedgie
                        quote Mumbles:
                        I had it running at least 5-6 years ago, but the case leaked, so I put it away until recently. The sealer is easier to work with than the scotchgrip as it is not as stringy/sticky when applying it. Gave it more than a week to cure because the test tank was frozen solid.
                        I think today I will pop in some Atom modules and see if that will improve the idle.
