Home › Forum › Ask A Member › Mark 25 steering
  • #7627
    cheetahgod
      Does the mark 25 have cable string steering or hydrolic? Does anyone have a picture of how the steering connects
      #61510
        there is a hoop part that bolts to the motor in the front look for the 2 holes one on each side. I may have one if you need. getting hard to find. cable and pulley or push pull will work on it.
        #61608
          They show up on ebay once in awhile, probably more often than the Mk20. The steering swivel to connect the cables to the hoop don’t show up hardly ever. Only seen one. A inventive person could probably figure out a work around
          #61626
          cheetahgod
            Do you know where I could get that attachment?
            Picture of my mk25
              what kind of boat are you going to use it on?
              #61629
              cheetahgod
                boat
                  with that boat they used a rear bar on the race motor. would need to be made custom for yours.
                  1 914 310 7086.
                  #61637
                    Dave’s correct. Too bad that it’s not interchangeable with a Mark 20, have a bar with your name all over it.
                    Kirk
                    #61669
                      I may have a wizard rear handle that can be put on the mark25 and a steering bar then mounted.
                      #61670
                      cheetahgod
                        I have a mark 20. But would prefer to put the mk25 on my boat.
