Home › Forum › Ask A Member › Mark 25 powerhead
  • #272060
    davidk
      I’m hoping to put together a Mark 25 out of components from my parts pile.  Is there a way to identify the 18hp vs. 20hp powerhead?
      Carburet0rs:  Looks like there were two different Tillotson carbs used on the Mark 25’s.  AJ47A on the 1955 18hp and AJ50A on the 56-58 2ohp.  They look identical to me, except for the fuel strainer.  Would either carb work on either powerhead?
      #272062
        no real difference in them just marketing. serial ###  would tell . give us the ### and i can look it up.
        #272065
        davidk
          Is there a serial number on the powerhead?  I know it’s usually on the plate on the transom clamp but these heads are long separated from their shoulders.
          #272066
            yes, on the block. at the crank case seam.
            #272067
            davidk
              Great, I’ll check there.  Thanks!
