Home › Forum › Ask A Member › Mark 25 fuel oil mix
Viewing 10 posts - 1 through 10 (of 24 total)
  • #7947
    cheetahgod
      What oil and how much should be used in the gas with a mark 25?
      Also what lower unit oil does it take?
      Thanks
      Jason
      #63369
      cheetahgod
        Also where can I find cheap coils for a mark 5?
        #63372
          Not sure about the oil mix but I know it’s out there or someone will reply. As for the mark 5, I think it’s uses the bendix coil? If so there’s no such thing as a cheap one. Old outboard Jim sells them for about $60 a pop.
          #63373
          jw-in-dixie
            Mercury specified TCWC3 certified oil, mixed 50:1. I use 40:1 in all of my old green and white Mercs, just as a precaution – oil is cheaper than parts and more available. Have used Tech brand from Walmart for years. Use lower unit oil recommended for shift gear boxes.
            Mark 5 coils – is that Bendix or Phelon? Old Outboard Jim may have them.
            #63374
            cheetahgod
              phelon
              #63375
              cheetahgod
                Will these coils work?
                http://www.rockauto.com/en/moreinfo.php … 14&jsn=257
                #63376
                mercuryman
                  Yes I have used them seem same a Phelon
                  #63377
                  cheetahgod
                    ok thanks.
                    #63382
                    David Stanton
                      According to the Old Outboard Handbook, Mercurys from 1956 to 1962 get 6 ounces of oil per gallon, which is 21 to 1, and double that for racing. In 1963 Mercury went up to 50 to 1.
                      cheetahgod
                        I thought it was 50:1 with modern day oil
