Home › Forum › Ask A Member › Manual for firestone 3.6hp
  • #197081
    seahuntboater
      She is Rusty and frozen. I will definitely need a parts list. I am not sure if it is Scott or West Bend
      Firestone 3.6hp Code is 133-7-1075 stock number 10-A-111 serial 10751146. This is 1956-1959 . Carb is Tillotson AJ16A
      I have her soaking with marvel at the moment but want to make sure gearcase is ok.
      Regarding gear case I only see one nut under cavitation plate. There is no spring clip as I have seen on other old motors I have messed with. How do you get the lower unit off?
      Really appreciate any help to save this one. I’m gonna need it.
      Thanks
      Ralph
      #197084
        It’s a 1957 by Scott-McCulloch. Does it have a shift? This is as close as I have (1953 non-shift). As you can see, take the front cap off to access the second nut.
        Lower-Unit
        #197090
        seahuntboater
          Thanks Frank. It is non-shift. I figured I should check gears before I start trying to turn the flywheel. Checking anyway would be good.
          #197252
          retiredoz
            Ive got an owner’s/operating/servicing manual and parts list for a ’52, I can’t imagine it’s different from yours in any serious way. That motor was Scott’s real winner, and they didn’t tweak it much over the 20 – or so – year run..
            Send me an email at retiredoz at yahoo dot com and I ‘ll send you pictures ( this site won’t let me ).
            #273942
            GravelyShoals
              parkerbuilders66@yahoo.com
