Home › Forum › Ask A Member › making springs from piano wire
- This topic has 16 replies, 4 voices, and was last updated 6 years, 10 months ago by
Tubs.
December 25, 2019 at 3:45 pm #189960
any hints or special technique to form small springs from .029″ inch piano wireβ¦.??
December 25, 2019 at 6:27 pm #189966
December 25, 2019 at 11:41 pm #189974ok good start I’ll try something similar
…I am the proud owner of 660 feet of .029 tempered wired for the price of 1 spring β¦β¦. so I can make a few mistakes π
my 9.5hp choke plate needs a new spring
December 26, 2019 at 12:08 am #189980Wire 0.029 is pretty heavy piano wire. What is the proposed spring to be used for? And .. what size spring are you hoping to make?
As for actually making springs from piano wire, not a problem, just a cold forming process. Of course some trial and error may be involved as there will be considerable “spring back” after forming on whatever mandrel one uses. You will find that the mandrel size will have to be considerable smaller than the desired finished spring size…. trial and error.Joe B
December 26, 2019 at 2:02 am #189984Disappeared post
December 26, 2019 at 3:32 am #189988Try number seven
Moor loops decreases the tension. On some outboards the pawls could drag at a slow idle. The extra turn decreased the tension so the pawls would extend at a slower speed. Of course heavier wire increases tension. – about those old “Simplex” auto rewind starters. – Because of minor variations in sand castings and the fact that the hole a screw goes into must be slightly larger than the screw, the hole in the starter housing is larger than the shaft of the spindle that holds the rope pull in place. This allows the bully to be centered over the crankshaft with a 3/16″ rod. Most starter damage happens when the housing is tightened with the projections on the rope pull pressing on the pawls. The pawls are always extended at rest. So when replacing a starter housing, first pull out the rope. When the housing is resting lightly on the pawls, allow the rope to retort and the projections will drop into place when they slide off the pawls. Then of course the pulley must be centered before the screws are tightened.
December 26, 2019 at 3:35 am #189990Try number eight
December 26, 2019 at 3:43 am #189992try ten
December 26, 2019 at 3:45 am #189993Eleven
December 26, 2019 at 9:35 am #189999JOECB β¦.when I measured the choke plate return spring on my MQ 9.5hp β¦..it measured .0255 I did not want to go smaller and .0255 was not available where I looked
so I went .029yes it is a bit bigger …but I am confident I selected a good size that will do the job I need it for .
Thanks for all your replies.
btw if anyone needs .029 spring drop me a PM and I’ll mail some out …for the postage only. I got a few feet to spare π π π
