Home › Forum › Ask A Member › Magnito recharge
Viewing 10 posts - 1 through 10 (of 22 total)
  • #6567
    mdn5
      I need some one with the skills/ equipment to re charge 1931 evinrude 402 magnito.
      I am in New York metro area but will travel
      Thanks,
      Mike
      914 769 6689
      #54568
        Steve Woods has a Stevens Magacharger here in Florida. He always takes it to Tomahawk when they have there National meet. . . 😉
        #54569
        sydinnj
          They are great chargers
          #54572
            After a few years of searching for a Stevens Charger and coming up empty, I ended up building one.
            mdn5
              Do you sell a schematic for your charger?
              #54629
                Mumbles, What kind of blocks (to fit the contour of the flywheel, etc.)
                did you make for your charger?
                rudderless
                  Damm…look at the size of those charge coils. Thats whats important..the rest is in the pic!
                  #54636
                  rudderless
                    Rectifier is square at bottom. Momentary switch on far right. Red lite shows power to the system. Green lite shows DC to the coils. Toggle is for polarity. Degauzing cap to protect switch from arcing. And a DC meter with 10 amp max. I am interested in the reason for the cap as one wouldn’t switch when charging..
                    All a guess…just trying to bait Mumbles..
                    #54640
                      The semi-tryangular blocks that come with the Stevens MagnaCharger have three radii corresponding the the three most popular flywheel magnetos. There are several on line plans for magnet rechargers. . . 🙂
                      #54643
                        Garry, thanks for the information. I’ll file it for the future.
                        I made a charger a dozen years or so ago, when I was
                        working on Hit and Miss engines to recharge some
                        Wico EK magnetos. They only required flat stock
                        to set up for charging. If I ever find the need to
                        recharge an outboard flywheel, I’ll have to come up with
                        some curved stock, with the correct radii, as you stated.
                        I have a lathe and a hacksaw to work with! Just wondering
                        what Mumbles came up with, and how he made them.
                        Thanks.
