Home › Forum › Ask A Member › Magneto control lever Muncie 1B39
  • #283648
    Frank Cornine
      Looking for a control lever for a 1939 Muncie model 1B. Purchased several that I was hoping would work but after installing the aluminum side covers the lever is unable to operate because it rubs on the front of the side covers. I purchased a nice one from the Penn’s Old Outboards but that one didn’t work either. If anyone can provide any leads it would be greatly appreciated.
      Thanks, Frank
      #283649
        could the cover be the problem?
        #283660
          When moving parts from one motor to another on the early motors it’s
          not uncommon to have to make some adjustments to get a replacement
          part to fit. I suspect your issue is the underside of the magneto lever is
          contacting the side covers. As you have several magneto levers with the
          same result it indicates that you need to make and adjustment else
          ware. You could remove some material from the magneto lever where
          it contacts the magneto plate, remove some material from the underside
          of the magneto lever, remove some material from the covers, or a
          combination of.
          #283678
          Frank Cornine
            The side covers are the correct ones for the Muncie 1B39 motor. The magneto control levers I have are not the correct ones to work with the covers. I try to keep everything as original as possible if I can. Going to a AOMC meet in Framingham, Mass. on the 20th of this month and hopefully obtain more information or eve a picture of what the correct lever looks like. Thanks for the reply.
            #283679
            Frank Cornine
              You’re correct, the underside of the lever is contacting the covers. The lever that I was trying to use is a nice cast aluminum that may have come from a Neptune outboard which looked similar to the Muncie. I could probably remove some material from the bottom without effecting the look and function of it. I try to keep everything as original as I can. I might just try that if I’m unable to obtain the correct lever. Thanks for your reply, much appreciated!
              #283680
              JOSEPH BRINCAT
                Posible that the mag plate is sitting too low? perhaps from wear on the hub and crankcase surface? If so, try a shim washer under the mag plate.
                #283682
                Frank Cornine
                  Thanks for the reply. I’ll check that!
                  #283705
                  davidk
                    Got any pictures to share?
