Home › Forum › Ask A Member › mag assembly swap ON LIGHTWIN/flywheel torque specs?
  • #1354
    bob
      GENTLEMEN…I HAVE A COMPLETE AND GOOD MAG ASSEMBLY FROM A 1972 EVINRUDE 4 HORSEPOWER WITH THE SIDE THROTTLE CONTROL LEVER.CAN I SWAP THIS ASSEMLY AND INSTALL ON A 1962 EVINRUDE 3 HORSEPOWER,OR JUST BETTER TO SWAP THE COILS,POINTS AND CONDENSERS.ALSO,THE FLYWHEEL NUT TORQUE WAS 40LBS.ON THE 4 HORSEPOWER.IS THE FLYWHEEL TORQUE 40 LBS.ON THE 3 HORSEPOWER AS WELL?THANKS,BOB
      #14925
      chinewalker
        The plate itself should swap, but you’d need to swap around the underside bits from the early plate to the later plate.
        #14942
        bob
          thanks…there is going to be some difference in the plug lengths,but that can be remedied if they are not to short.Is the torque for the flywheel nut at 40 lbs.for the lightwin 3 hp.?
          #14949
            Actually 30-40 ft pounds on both.
            #14954
            bob
              THANKS FRANK,APPRECIATE IT.
