Home › Forum › Ask A Member › Lower unit swap?
  • #3064
    philj
      Hello gentlemen,
      I would like to know if I can replace an Evinrude 1966 6hp lower unit by one from a 1959 Johnson 5.5hp I have?
      Thanks for your answers…
      #27732
        I suppose you can if you use the complete unit. But there are significant differences. The ’66 has a shift rod disconnect, ’59 does not. So you will have to pull the powerhead to install it on the ’66. Also, ’66 does not have a shock absorber in the lower unit, and has a different prop shaft requiring a different prop.
        #27828
        philj
          Well that’s real good information, thank you!!!
          Today I found the same 6hp I bought for 75.00 CDN, this time it’s a Johnson 6R71E which I suppose is a 1971 model… But why is there a "E" at the end??? And this time would it be identical for swapping gearcase and lower unit?
          Thanks in advance…
          #27832
            Without pouring over the parts books, I believe it will be a direct swap. The E at the end denotes any mid-year engineering changes that were made—IF there were any changes. If no changes, it means nothing.
            #27836
            philj
              Many thanks, FrankR !
              #27920
              edgartc
                I put a 68 6hp LU on a 63 5.5hp, just had to change the shift rod, works fine.
                #27938
                philj
                  Thank you everyone!!!
