Home › Forum › Ask A Member › Lower unit on a speeditwin
  • #83244
      #83429
      destroyer85golf
        Wanted to thank you guys for all your advice and help! Went ahead and welded a plug into the front and ground it smooth. Got a picture of my son watching his grandpa welding on the lower unit.
        George Emmanuel
          Whoa there! Heat distorts and that plug need not be welded.
          George
          #83464
            I don’t understand how this happens. I posted this yesterday and it disappeared – so I will post it again . . . 🙄
            That Rotary valve Speeditwin came out in the early ’30s with battery ignition as an Elto Super "C" and with a flywheel magneto as an Evinrude Speeditwin – That Elto pattern gearcase was the best for speed and was reproduced by Clyde Wiseman (Wico Piston Company) for "C" service racing.
            It became totally Evinrede in 1939 with the 6039 model. It was built with three distinctively different lower units.
            Yours (the middle one) has the gearcase designed for the Army Stormboat Motor of World War Two. Designed to run up on hostile beaches. it is very rugged and is the slowest of the three. Many owners cut off the "wings to reduce drag. Evinrude noticed and when the supply of Stormboat Motor lower units was used up ( they were working on an order for 5000 storm boat motors for the invasion of Japan when President Truman dropped the A Bomb and ended WW2.) the next production run was cast without the projections.
            Here is the parts book for your Speeditwin –
