Home › Forum › Ask A Member › low cost carb kits ….
- This topic has 25 replies, 12 voices, and was last updated 5 years, 8 months ago by
JACQUES.
March 2, 2021 at 9:12 am #232670
posting link info because of display failure
ok I know some carb gaskets (orange) haved melted but… at $5 you get misc parts and a float !!!!
https://www.amazon.ca/gp/product/B07VB2M5T4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
March 2, 2021 at 9:31 am #232675Are these carb kits on Amazon .ca.Called OMC dealer in Woodstock ont yesterdy for needle valve packing washers.$5.50 each and carb kit now $50.00. Russ…
March 2, 2021 at 9:37 am #232676image wont link to amazon … recopy the link info in the attached picture carb-link .jpg to reach it
hurry they are going fast
March 2, 2021 at 10:30 am #232680https://www.amazon.ca/s?k=b07vb2m5t4&ref=nb_sb_noss
US Version is more $$$
https://www.amazon.com/s?k=b07vb2m5t4&ref=nb_sb_noss-
CHUCK.
March 2, 2021 at 11:47 am #232686the kit included a $2 coupon rebate but ordering 5 only gave a $2 rebate….. call me cheap… I expected 5x$2 in rebates π ho well I should have ordered 5 individual kits π
btw these kits probably have the metric jet which don’t fit but for the price the other parts are fine
JACQUES.
March 2, 2021 at 12:15 pm #232691The threads on the float valve are not metric but just haven’t been cut deep enough and require chasing with a dye. After chasing the threads, they work great.
March 2, 2021 at 12:28 pm #232694what thread size dye should I use to shape it ?
my error seems I read not to long ago it was metric… if not well that is great news ..i’ll have a few spares π I gave up on because they would not screw in the carbs
I will try to recut the threads with my famous “Master Craft” kit π
JACQUES.
March 2, 2021 at 1:17 pm #232697March 2, 2021 at 1:28 pm #232700I’ve used some of these style Chinglish kits in the past and haven’t had any problems with them yet, although the motors with them on haven’t been used much. One thing I found besides the float valve threads needing chasing was the plastic washers for the packing washers are too large and I had to use some spare left over ones. Maybe I should pull a carb off and check the condition of the gaskets as It’s been close to a year now.
These cheap kits are also ‘Add On’ items with a purchase of $25 or more. Time to go shopping soon!!
March 9, 2021 at 12:20 pm #233364Ordered some of these kits to have a look and give them a try.
Got some for big twins, and some for smaller motors like 18, 10, etc.
As mentioned, the threads on the needle seats required a little work, but otherwise look fine!Thanks for the “heads-up” guys! Good supply of bits and pieces.
Bill.
P.S. The floats are hollow, instead of being made from foam.
Larger kits seem to be missing the main jet seal.
Smaller kits also contain a fairly large do-nut that looks more like a shift-rod seal? -
