Home › Forum › Ask A Member › Loose Piston STUCK RINGS
  • #300624
    green-thumbs
      An otherwise good piston with all 3 rings stuck flush. Tried WD40 and later electric heat gun without results, My batting average with really stuck rings would not get me a spot on a sand lot team, Am I on right track with heat or are ther techniques those in the know use?
      Is this a job for Gibbs?\T
      Thanks
      Louis
      #300626
        How about placing the piston in the oven set at 200F?  Needless to say, you can’t save the rings, don’t chance it…
        #300632
        Maybe try Kroil
        Steve
        #300633
        wedgie
          ultrasonic cleaner .
          Put piston in glass jar filled with transmission fluid. put lid on jar. Submerge jar in ultrasonic cleaner with heater. run many cycles over a few days.
          #300635
          Sam M.
            Tubs has a video about this on Youtube.  I think a lot of tapping did save a seized piston ring if I remember correctly.  I’ve read that a different approach to this is to run the motor with the stuck rings and they should free up, but this is not a reccomendation as I haven’t tried it.  Just providing ideas.
            #300636
              I have used  Dupont teflon on realy hard stuck bolts…the stuff seems to have a high  capilary effect  and releases stuck parts.
              I use this stuff…not common everywhere I  guess
              Dupont Teflon Snow & Ice Repellant, 284-g | Canadian Tire
              #300637
              RICHARD A. WHITE
                I follow the Chris Scratch method…
                Using the handle of a small hammer, ball peen style, gently tap the ring area, starting nearest the gap. It will eventually loosen the ring.
                Using some solvent, such as Kroil won’t hurt.
                Currently did this to a Lockwood Ace piston ring… ring not broken, but now free… now to gently remove it from the piston so that I can clean the grooves properly.
                Respectfully
                Richard White
                classicomctools@gmail.com
                #300638
                  I do have a video from 10 years ago removing a ring from a Rowboat Motor piston. Here is the link. https://www.youtube.com/watch?v=fWMUDYfhqW0&t=28s   While I was 100% successful removing these 3 rings, rings become thinner in years to come. My percentages on the thinner rings is slightly above “O” when they are stuck like the one in my video.
                  #300639
                    https://youtu.be/Qv5wdIB3LVQ
                    #300640
                    green-thumbs
                      Add this to youre Does Not work and Shold Not be Tried
                      While wife was out shopping, I baked pistont at 500 degrees
                      until it was hot and then some, Pulled it out with tongs and
                      applied wax to are of rings,, The rings are still stuck and the house stinks from whatever was on piston .Heat and wax has worked well in other applications, but, not this time,
                      Louis
