Home › Forum › Ask A Member › Loose low speed needle bushing
- This topic has 7 replies, 5 voices, and was last updated 3 years, 4 months ago by
robotmark.
May 8, 2023 at 4:08 pm #276046
Hi folks, I was tuning up the carb on my 1971 40 hp Johnson (model 40ELL71B) for spring and noticed that the bushing on the low speed needle valve assembly is loose. If I tighten the needle so that I can then back it out to right specs in the manual, the needle and bushing just spin inside the shaft. I have to pull the whole thing out and start over. I could order a new bushing, which isn’t a big deal but I also wonder if the issue is not enough/too much packing. Has anyone had this trouble before, and if so, what did you end up doing?
Thanks!
May 8, 2023 at 5:46 pm #276048No problem. Pre-assemble the nut, packings, and bushing onto the needle. Have the needle backed out of the bushing more than the final setting will be. Poke the whole thing into the carb. Tighten packing nut enough to make the bushing stop spinning. Turn the needle in till lightly seated and back it out to preliminary setting. finish up with tightening the packing nut to hold everything snugly after final adjustment.
May 8, 2023 at 6:08 pm #276049Great advice. I’ll give it a try! I always have everything in the hole and thread the needle last. I like the idea of the pre-assembly. Thanks so much 🙂
May 8, 2023 at 10:16 pm #276067June 18, 2023 at 12:25 pm #277109Just wanted to say thanks, everyone! It’s been raining non-stop for the past six weeks, but I was finally able to take it out for a run yesterday. That little Johnson ran the best it ever has. We were flying across the lake. Thanks again!
June 18, 2023 at 1:57 pm #277111great news thanks for your feedback . .. TLC and 40 more years to go !
June 18, 2023 at 5:51 pm #277117
Sounds like your in Maine.
June 19, 2023 at 1:47 pm #277135Nope, I’m in Colorado which is not exactly famous for its boating! I’m originally from New Hampshire, though, and that’s where my dad had his vintage outboard collection that got me started.
