Home › Forum › Ask A Member › Loose brass bushing in magneto plate
  • #189697
    olcah
      Looking at a magneto armature plate removed from a 1954 Johnson 25 HP. (Part no. 580168. As far as I can tell this mag plate fits all the mid fifties OMC motors.) I noticed that the cast in center brass bushing can be moved up and down slightly. Usually when I see this I replace the mag plate but yesterday it occurred to me that the plate is actually screwed down into a ring that will tend to hold the plate in position. If that is so it seems to me that the bushing would be ok even if it is a little loose in the mag plate.
      Wonder what others think about using that mag plate as is? Thank you.
      #189698
        They are so plentiful that I say replace it.
        #189742
          Agreed, chuck it and find another one. These style mag plates are pretty much universal but a replacement may need a hole or two drilled and threaded to match the original.
          On second thought, the ’54 plate might be a bit different than later plates. A ’54 Evinrude 25 I had used a cable to turn the mag plate. Not sure if the Johnson 25 is the same.
          • This reply was modified 6 years, 10 months ago by Mumbles.
          #189750
          olcah
            Thank you Frank and Mumbles.
            Yes, both 1954 Johnson and Evinrude 25 HP are the same cable set up. The cable runs/connections are made on hardware screwed to the back of the plate so no problem. I will replace as I have done previously.
