Home › Forum › Ask A Member › Looking for wico x8795 coil or possible replacement
- This topic has 28 replies, 7 voices, and was last updated 4 years, 5 months ago by
Bob Wight.
May 6, 2022 at 6:46 pm #259506
Hey fellas i need to replace a wico x8795 didn’t know if any one had one or knew of a replacement thanks in advance thanks
James
May 7, 2022 at 11:17 am #259520Coil looks like it has seen better days, so take it off the laminate by cutting thru one side with hack saw, place assembly in vise and driving the laminate out of coil.
Next step measure the laminate pole the coil was on and look for a cheap coil that will fit with or without trial and error fitting, It may seem a bit CRUDE, but, adapting a currently available coil beats looking for something that may ve HARD to find. IF you are VERY lucky you may find a used coil at a small engine shop (used) for a nominal sum. Be aware that small engines went to solid state systems about same time as outboards. Coil needs to fit into the available space , fit on the laminate and a high voltage output that can be routed thru the magneto plate without interference with anything such as flywheel. cam or points.
I am probably the least qualigied to advise on magnetos. There are those wo REALLY know the subject on this site They may have specific suggestions to address situation.
Louis
May 7, 2022 at 11:47 am #259521
If that is the 2 cylinder coil options are limited.
If that is the single cylinder coil I used a spare
(as in free) common OMC style coil in this Wico
magneto.
Tubs.
https://youtu.be/tVvSB5QxMrwA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
May 7, 2022 at 12:48 pm #259524Hi yes its a twin from my beloved lauson 6hp now i have two non runners so its time to do some experiments
May 7, 2022 at 1:52 pm #259526A John Deere pony motor coil might work but you may have to modify the pole laminates for the JD coil to fit correctly.
This reply was modified 4 years, 6 months ago by
Bob Wight.
May 7, 2022 at 5:59 pm #259541Anyone have a part number of the john deere coil i found this one but not sure if its the right one thanks
May 7, 2022 at 7:48 pm #259543
That looks to be the coil. This was posted
by MAS in 2014. I believe he was as successful.
Others have also attempted this but they
weren’t successful. You are not the first to be
looking for a solution to replace this coil as
it is often bad. If you do attempt this taking
pictures with explanations would be helpful
for others in the same position, if you succeed.
Good luck.
Tubs.
May 7, 2022 at 10:38 pm #259545Yes definitely will take pictures and post part numbers if this works fingers crossed
May 8, 2022 at 1:12 pm #259580This is interesting as I have a Lauson T600 Twin and it has an Eisemann 62D Magneto. OP hondaatc’s Lauson Twin has a WICO?
May 8, 2022 at 6:12 pm #259591Yeah i have two twins one has this wico ignition and one has the eisemann but thats lauson for u
