Home › Forum › Ask A Member › Looking for help finding skews (lower unit ) for Evinrude 1940 to 1947
  • #289007
    paulde51
      I am working on a 1946-1947 Evirnrude Ranger 1.1 ho 4407.  It is in great shape except the skeg is broken and I am trying to find a replacement for it.   If you know of a parts motor that I could get a good keg (lower unit from) please let me know.   I understand that the Elto 1940 1941 Pal is also the proper fit.   Thanks for any help here.  Paul Hastings
      #289010
        how bad is it ?   trashed ? .. partly broken. ?…they can be welded
        I have even used JB weld (10$)  instead of a 300$ weld job for a small section  of skeg on 75 hp ETEC .
        the asking price  was so ridiculous  I got  creative.
        sanded and  spray paint finished with  Etec Blue …….  certainly good enough for me
        #289016
        paulde51
          My apologies.  My title should have read skeg not skews. (auto correction got me).   I believe the part number for this gear housing which is part of the skeg is 195 587.  Thanks so much.    I have thought about taking it to an aluminum welder but I imagine it would be very very expensive
          #289018
            if the housing is not cracked you can fix it with JB weld.
            just dont  rest the engine on the tip  you fixed   or  hit…rocks !    paint it silver
            nobody will know but you
            I used a flat  blade .       I  clamped  a  drywall spatula  (6 inch)  wipe with oil  and worked the top side to shape the  skeg.
            just clean the ragged edge with   carb cleaner  to help adhesion of the jb
            #289023
            paulde51
              Thanks so much for the repair help with JB weld.   The problem I have with this method is that I do not have the broken off part of the skeg.   I was thinking about trying to cut off the skeg at the base and cut out a whole new piece and shape it and then having it welded on.  ??????
              #289024
              green-thumbs
                If you live in an urban area, there probably are several weldeing shops that work with aluminum. One or more may be willing to repair the ske on a one off cash money basis. It can be done, You may expect to finish job with file and sand paper to get finish and profile.
                Finding a replacement part for an 80 year old outboard that may not have been common and for a part that may have been a frequently damaged component may take some doing,
                JB Weld probably is not suitable for repair of a broken off and missing portion of skeg.
                #289025
                  I did not have the broken section on my 75hp….I just reshaped the JB weld…   used a grinder to shape  it.
                  then  used a sander to smooth out and match  the surface.   much like finishing plaster on a wall with 100 grit paper.
                  welding of course is the best  but for just  10-20$ of JB weld  it worked for me  so…. if you are  handy  with such work try it
                  up to you
                  wasn’t perfect for purist  but  it came out fine  and rock sold
                  #289030
                  paulde51
                    If I can not find a parts motor then I will either JB weld or I would at least like to get a quote to have one welded at a shop.    What I would love to have is a paper tracing of this piece.   I believe it is 195.587 in the parts manual.  If someone could trace this piece I would be really grateful.  Thanks for you help
                    #289033
                      just use  that  picture you posted and adjust it to size on powerpoint
                      takesa few tries  but you can get a good match
                      #289034
                      MIKE SIMS
                        Also check your local prop shop. They weld aluminum props all the time and may do skegs.
