Home › Forum › Ask A Member › Looking for gear case seal
  • #3551
    fishingnuts
      The old seal is on a 9/16 shaft, OD is 7/8 and the width is 3/8. Been surfing the net but not finding. Found some a month ago, with a chart but not finding it again. Appreicate any help.
      #31250
      RICHARD A. WHITE
        For which motor?
        classicomctools@gmail.com
        #31251
        fishingnuts
          1957 Champion Majestic M-2N
          #31252
            Let me look through my parts. I am slowly working towards building seal kits for every motor. I have not got to the Champions yet. Ill get back to you.
            #31256
              Look up Motion Industrys. They have many seals & bearings going by size. Take to the counter guy & he may have several different seals that will fit
              #31258
                The only issue with that Jeff is they sometimes sell you a steel seal. Ive tried them as experiment, after a season the shell is rotted out.
                #31268
                JOHN D.
                  You might try a metric size as in 14mm X 22mm X 7mm. It’s only a quarter inch thick, but they worked on my Voyager’s gear shift gear box. The outer diameter of this seal seemed too snug of a fit so you may have to enlarge the hole in the end cap. This is a fairly common size as I noticed that Honda motorcycles use them.
                  #31282
                  fishingnuts
                    The seal that was leaking, I removed from the gear case. It was all rubber. I checked with Motion Industries, trying to find a brass or all rubber seal.
                    No luck so far. I’ll wait on Chris, see what he comes up with.
                    Thanks
                    #31300
                      Well, I think I have a solution, or two.
                      I can either A:
                      Have a run made of these, custom made, but I would have to order 500 min. I normally don’t mind that, but Im not sure this would be a very popular seal kit to sell. If I ordered 500, my grand kids would still be selling them I would think.
                      My other option, is I can piggy back on another guys order, that is VERY similar. The only difference, is that these would be half the width, 3/16" wide, not the 3/8" you mention. that is not really an issue, as you could stack 2 seals in there, front to back, and would really get a better seal that way anyways. Is the drive shaft seal the same size on the Champion? I wonder if any other brands would share that size seal?
                      Anyways, if that interests you, let me know.
                      #31306
                      fishingnuts
                        When I pressure tested the gear case the drive shaft did not leak. Size unknown.
                        I would like to order two seals. please advise the cost and method of payment. I have pay Pal.
