Home › Forum › Ask A Member › Looking for Evinrude Zephyr carb or parts for carb
  • #6288
    Hey, have a running Zephyr but need to replace the needle for the needle and seat assembly. The end of shaft broke off where pin inserts to hold spring, applying pressure up against seat. Anybody with experience with this issue and is there a way to fix the needle shaft??
    Thanks in advance
    #52532
    wyo307
      I had the same problem with mine when I got it. I ended up picking up a whole other carb just for the needle essentially.
      #52544
        Lightfours and Zephyers use the same 275201 inlet needle and seat assembly. . . 😎
