Home › Forum › Ask A Member › looking for a prop and prop nut for an early 60’s OMC 18 hp
  • #2133
    boatman
      Hi,
      Hoping someone might have a prop and prop nut and recoil assembly for an early 60’s OMC 18 hp.
      Paul (Chicago area)
      312-933-0600
      #21084
      rmhxruss
        390716 prop nut
        306394 cotter pin
        307949 shear pin
        763583 prop
        Your local OMC Burp dealer can get these for you.
        #21124
        boatman
          Russ,
          Thanks much! Hoping to find someone parting out a motor, but good to know where I can get them.
          Paul
          #21132
            Boatman
            Have You tried Doug Penn?
            He’s very helpful and has a good stock of used parts.
            http://penn.itgo.com/
            Steve A W
            #21485
            newness63
              Hi I have a near new prop for that motor. Ill check for the nut. Jim $50 plus postage
              #21501
                You might try Dan Gano as well. Dan sells old OMC parts only & has many bins full of 50’s & up motors. Reasonable prices too.
                Dan had everything I needed for my 58 Johnson 18hp motor. Runs well now plus it’s electric start too! Thanks Dan as my E start was bad
                http://WWW.GANOTECH.COM or (712) 336-3297
                Good guy to deal with for OMC parts only!!!
                Jeff
