Home › Forum › Ask A Member › Long Turnover Time
Viewing 11 post (of 11 total)
  • #47593
    oltimer
      quote mrbrightside7:
      Hey all! Thank you so much for the suggestions. To answer a few of the questions asked, this is a new boat to me and it has done it has lagged on startup since I’ve had it. I will admit that this is probably very much user error here as after reading all of the responses there are so many things I did not know about. Mainly the warm up/fast idle throttle lever, I had no idea that was something I need to do. I will troubleshoot according to the things you guys mentioned here and will see if anything helps! Thank you all so much!!
      Thanks for responding to our questions. An easy trick to see if your electronic primer is giving gas to the carb when priming with the "push in key method"; is to change the small black line going to the top of it with a clear line. You will know/see immediately if gas is being pumped, or if your primer needs a over haul with new seals. Good Luck
      Jer
