Home › Forum › Ask A Member › Lockwood Racing Chief
- This topic has 16 replies, 8 voices, and was last updated 9 years, 4 months ago by
jerry-ahrens.
March 3, 2016 at 1:35 am #3754
Edit: Found this the other day. After driving 4 hrs in a steady down pour to look at it I was sure to buy it. Seems to be in pretty good shape….on the outside anyway. From what I gather it’s a 1929 Lockwood racing chief. It’s not supposed to be one of their better racers and made just a single year. Peter Hunn’s book shows one with the twin carbs removed after its racing career was over and a single carb added for ease of operation. That’s the way this one is. I thought I saw an old picture of one with a single carb. Maybe they let a few out of the factory that way? I thought I was pretty good at scowering the internet for info but I really can’t find much on this model or any other Lockwood’s for that matter. So if anyone can send me any info this way I would sure appreciate it!
GlenMarch 3, 2016 at 2:04 am #32811Anonymous
Gorman,
Great find!
Chris Scratch is very knowledgeable on Lockwood outboards. Plus heads up the Special Interest Group for Lockwoods for our club. I am sure he will chime in and assist.Respectfully
March 3, 2016 at 2:08 am #32812Well, that is fantastic! Always hoping to find one, but usually end up with a Clinton Chief lol.
March 3, 2016 at 3:34 am #32817Anonymous
It’s true that many of the Racing Chiefs seem to have been changed over to a single carb and stock manifold arrangement, but as you mentioned in your document, this was done mainly to make the motor more user-friendly.
I do not believe there was any reason for Lockwood to install a single carb on a 92BR at the factory. The dual carbs would have been what the racers wanted in order to achieve best performance.
The racers would have had the dual carbs with air horns and progressive sliding linkage, as well as a special angled adapter at the base of the tiller arm mount in order to allow the tiller arm to be canted at an angle so as to clear the port-side carburetor/air horn assembly. The Service Chief used a two-blade prop that was 9 inch X 14 pitch, where-as the racers used a 9 X 15 or 16 pitch. The Lockwood Ace and Chief props have the diameter and pitch stamped on the hub, check yours to see which one it has. Probably 9 X 14, it’s the most common one.
Racers also had aluminum rods from the factory. You can check yours by pulling the intake and carb off and looking in through the ports. If its still got aluminum rods in it, and the crankcase isn’t welded anywhere, consider yourself blessed, but I don’t recommend that it be run it that way. It yours has bronze rods, it’s been modified by more than just changing the carb and intake… and that modification is considered an upgrade, the bronze rods are stronger. It is common to find a Racing Chief with a welded crankcase and bronze rods installed. The aluminum ones didn’t stand up too well, and when they came apart, well let’s just say it didn’t make a pleasant sound and didn’t paint a pretty picture…..
Oilers – it seems that some 92Br’s have shown up with Lunkenheimer No 2 Figure 1300 oilers installed….. but I think to be 100% correct, it needs to have Michigan Lubricator oilers on it that are identified with the number X48A4 stamped on the outer rim. I have one of those oilers on my 92BR, still looking for the other, they are every bit as rare as sensible Presidential candidates on Super Tuesday…
92Br’s used the Ace magneto and flywheel, it is smaller in diameter and lighter in weight than the service flywheels. I think the only other difference between the racers and the service motor, aside from the obvious cylindrical gas tank that only got installed on the 92BR, would be the size of bearing in the crankcase, and the crankshaft was drilled different to get more oil into critical spots.
Hope this helps.
Best,
T2March 3, 2016 at 3:41 am #32818Anonymous
One more thing – yes, it was built for only one year (I believe they were still available for sale in 1930) but that had more to do with the Evinrude-Elto-Lockwood merger than it did with the 92Br being a sub-standard performer. THe 92BR was a record holder and winner in the "B" class, it was the work of Lockwood’s Chief Engineer, Finn T. Irgens, and was probably the fastest motor he designed until he came up with the Speedibee racer.
I have a lot of Lockwood info. I’m hoarding it until my raise from the AOMCI gets put through. I’ve been told it might take awhile….
Hope this helps
Best,
T2March 3, 2016 at 9:50 am #32828Wow, lots of info there T2 thanks! The prop has some build up on it and can’t really see any markings but may become visible later. It looks to have set awhile so I’ll let the PB blaster do its job before I start wrenching on anything. Good news it’s not locked up. Hard for me to get started on it with another project going but you all know how that is. It does have the Lunkenheimer oilers. The flywheel does have LA stamped on it. I can get some better pictures as soon as I get this new computer figured out.
GlenEdit: According to the pictures on the Ashland Marine site the flywheel looks to be off of a 1928 Chief. Oh well…
March 3, 2016 at 1:17 pm #32838Anonymous
If you provide the outside diameter of your flywheel I can solve the riddle of whether it s a service flywheel or not. The picture makes it look like its an Ace wheel, but measurements will settle that. Do you have a link for the pictured motor you’re referring to on the Ashland site?
The rope sheave should not have a model designation on it, it should just have the manufacturer name and location on it. That’s because on the Ace rope sheaves, Lockwood did not indicate the model designation there, it was only on the crankcase just above the carburetor mounting collar.
Hope this helps.
best,
T2March 3, 2016 at 4:33 pm #32843The flywheel measured at 8” and does have a place for model and serial number on the rope sheave like the ’28 chief sheave at this site http://www.ahlstrand-marine.com/ under outboard museum then antique motors for sale. The motor is in a bad place and pretty dirty right now. I’ll have to try and find the numbers later. I did see the number 520 at the front bottom of the crankcase.
Thanks
GlenEdit: Someone scratched in RACE for the model number 🙂
March 3, 2016 at 10:09 pm #32852Anonymous
Ace flywheel = 8 inches in diameter
Chief flywheel = 9 1/2 inches in diameter
So you have an Ace flywheel with a Chief rope sheave. You just need to swap rope sheaves to make it correct for the BR.
Number 520 at the base of the crankcase is consistent with how the 92BR’s were marked from the factory. Mine is #550
‘Ope dis ‘elp dare eh
Regardez,
TayDeuxMarch 3, 2016 at 10:59 pm #32853Goman, the attached file says I need "Office" to open it.
Any way around that?Prepare to be boarded!
