Home › Forum › Ask A Member › Lockwood cheif 1929 carb help
  • #7621
    joe1
      So I have 2 carbs one has
      this hole an 1 dose not there was Nothing hooked up to it But it is a threaded hole If anybody knows what it’s used for I’d appreciate it thanks Joe1
      #61475
      PM T2
        Not supposed to be there. If its threaded, can only imagine that somebody drilled/tapped it to use as a mounting point for some type of bracket.
        Not going to speculate what the bracket might have been for, you’ll have to ask the guy that drilled/tapped it.
        Hope this helps.
        Best,
        PM T2
        #61601
        lyks2tinkr
          Just my humble opinion. If it’s an 1/8th pipe thread maybe a previous owner had a primer cup threaded in there.
          My 29 Chief doesn’t have a hole either.
          Don’t shoot me I’m only the piano player.
          #61602
          joe1
            that’s what I was thinking for a primer it comeing out ok ( Before and after photos )
