Home › Forum › Ask A Member › Lockwood Ace
  • #8224
    gofastgramps
      I have a Lockwood Ace that runs good on the stand but wont quite run in the tank. It has good spark and between 55 and 60 psi in both cylinders. Is the compression to low to run? also I could use the specs. for this engine. Thanks Gary
      #64867
      RICK EICHRODT
        Contact the Special Interest Group Leader for the Lockwood’s. His name is Christopher Scratch.
        #64868
          What your experiencing is typical for low compression.
          It may be the rings are stuck. Getting it warm and then
          letting it cool back down helps to free them up as the
          metal parts expand and contract. The detergent it todays
          oil along with repeated cycles of running and cooling will
          clean them up with time. A little sea foam in the gas
          might speed up the process. If you cant get any
          improvement you’ll need to pull the cylinders to see if
          they are still stuck or just worn out.
          #64895
          George Emmanuel
            Does your Ace have underwater exhaust or above water exhaust?
            George
            #64906
            gofastgramps
              above water
              #64927
              George Emmanuel
                Just curious because underwater exhaust does restrict and can make a worn engine difficult to start.
                George
