Home › Forum › Ask A Member › Lockwood 72T Coil Removal
- This topic has 73 replies, 9 voices, and was last updated 2 years, 8 months ago by
Tubs.
February 6, 2020 at 2:00 pm #194123
The Scintilla coil, which it looks like the military spec coil emulates,
takes a .17 to .21 mfd condenser, but being military “specs”,
who knows!Prepare to be boarded!
February 9, 2020 at 10:17 pm #194407When I first researched the 4A032 military coil I found a parts catalogue, which showed the capacitor as .25 mfd. I use OMC universal condensers (.22mfd) with no issues. The OMC condenser is just on the edge of the normal range so I don’t see any long term issues especially considering the amount of use the motors get.
Wayne
February 10, 2020 at 9:43 am #194435When I first researched the 4A032 military coil I found a parts catalogue, which showed the capacitor as .25 mfd. I use OMC universal condensers (.22mfd) with no issues. The OMC condenser is just on the edge of the normal range so I don’t see any long term issues especially considering the amount of use the motors get.
Thanks Wayne, I ended up using a .22 axial cap, which is just a hair over of what
a Mercury type Scintilla coil needs. I just “hoped” that the Military and Scintilla type
coil were close in specs…….. sounds like I’m close enough!
I’ll file your information for next time. Thanks!Prepare to be boarded!
February 10, 2020 at 6:57 pm #194494Watching the video, it looks like the flywheel is bent? Might have something to do with the failure?
George
July 1, 2020 at 6:27 pm #207370i am looking to do this re-fit with lockwood 72 is it the same ?
need help here thank you ralphJuly 1, 2020 at 6:51 pm #207374
July 2, 2020 at 7:04 am #207454HELLO SIR
Thank you for your reply
Rookie RalphJuly 2, 2020 at 7:19 am #207455Q. I want to do a coil replacement on my 72T but
I do not have the old original coil it is missing
what is needed to compete it
looking at how this can be done
ralphJuly 2, 2020 at 7:47 am #207460If you can get your hands on a “parts coil” it will make the process a lot easier.Lacking that,you’ll need to fabricate laminates to fit tightly between the mag plate heels and a long threaded rod to hold every thing in place.
July 2, 2020 at 8:08 am #207462
