Home › Forum › Ask A Member › Locked up 1929 Johnson V-45
  • #188302
    bayham3261
      I recently acquired a nice (99% complete) but locked up 1929 Johnson V45. If you look closely you can see a wooden gas cap someone made! It has been stored for a long time and who knows how long the engine has been locked up. I’ve been working on stripping the engine down and I have the power head nearly done. I haven’t had any luck with my normal trick for unlocking engines (propane torch, Seafoam penetrating oil with a lot of time and patience.) I’ve heard about soaking badly locked up engines in diesel or a diesel/ATF mix for. I was thinking of giving this a try with the engine block. I’d let is soak for the winter. Has anybody had luck with this? Any recommendations? Thanks!
      A little information is a dangerous thing!
      #188305
      LLOYD LAUTNER
        I have had luck soaking blocks and cylinders in a hot crock pot filled with antifreeze.
        #188307
          Are you sure it is the powerhead and not the lower that is locked up?
          #188332
          bayham3261
            Yes, the block is completely locked… no doubt about it. It is is possible that the lower unit is frozen too but it looks pretty good to me. I’m going to have the block off soon so I’ll see.
            Interesting idea with the antifreeze Llyod. How long do you keep it in the hot crock? do you bring it to boil?
            #188338
            Randy in Tampa
              I have a V70 that was locked up and used ATF/ acetone alternating sides to mostly free it up then an grease fitting and gun to finish the job after a few weeks 😎
              Rotary valve Johnson’s Rule!
              #188367
                I believe that is the motor I was looking at buying as well. Congrats!
                Alternating between HOT and COLD may free it up. Boil it in a crock pot, or oven, etc….then toss it out in the snow. Back and forth. I soak it in 5/:50 ATF and Acetone as mentioned before hand.
                Im not sure where you are in Ontario, but the snow is coming!
                #188373
                  ATF has a lot of detergents to keep your transmission clean plus a lubricant for the bushings. The highly volatile acetone will get it into the crevices. It works as well as products costing three times as much. Heat and cold uses the different expansion rates of iron and aluminum to break the bond between the two. The high pressure grease works well if you can seal off the ports. This can be difficult in four cylinder (double apposed) outboards, especially Johnsons which use a ported piston. Remove the cylinder nuts and work on the piston with the closed ports to gain access to the connecting rod screws. high pressure grease has been known to break out thin places the cylinder wall. this is less likely in cylinders with removable heads because the casting sand has more support and is less likely to shift.
                  #188389
                  green-thumbs
                    If you have not yet put your turkey cooker away,now may be the time
                    to try your favorite recipe for deep fried V45.!
                    Seriously, there are a lot of different approaches for dealing with stuck
                    outboards, Often it is the rings are rusted to cylinder wall, sometimes the
                    problem lies elsewhere. Lower ends can be stuck, needle bearings can
                    be swelled up with rust seizing crankshaft tight. Everyone has their
                    favorite cure or cures for what ails a stuck outboard. One size dones
                    not fit every condition. I have used the grease gun method on a number of early K Model Mercurys with mixed results. It is a kill or cure approach that gives results good or bad quickly. Several of my
                    motors did not survive. As the saying goes…mistakes come from lack
                    of experience and experience comes from making mistakes.
                    Pressure from grease gun will burst cast iron cylinders with only
                    a partial stroke beyond where you should have quit.
                    Magic elixirs sometimes work wonders.
                    A cautious , patient approach, well thought out ,give a better chance of
                    a good outcome than just getting out the big hammer.
                    Louis
                    • This reply was modified 6 years, 11 months ago by green-thumbs.
                    #188391
                    ROBERT LAFAYETTE
                      Please remember antifreeze is poisonous!! Do not use anything for cooking food after touching antifreeze!
                      Another idea is Avaporust.
                      Soak cylinders for a few days, see what happens?
                      #188392
                      ROBERT LAFAYETTE
