Home › Forum › Ask A Member › linkage disconnect on johnson tn 26 carb
  • #254402
    Brian Collins
      is there a trick to disconnecting the throttle linkage?…i want to remove and check the carb
      • This topic was modified 4 years, 9 months ago by Brian Collins.
      #254410
        Basic Carburetor Servicing Johnson H and T Series (pochefamily.org)
        service info also covered in the johnson red book
        did u download yourself a copy from Garry’s drop box in the library under INNER SANCTUM in the members only tab ??
        #254416
          There should be a small piece of stainless wire bent into an ‘S’ shape at the ends of the brass rod connecting the carb to the mag plate. A small pair of side cutters are your friend here to get it straightened out and removed.
          TN-Mag-Linkage
          #254423
            to re attach   you can use small SS wire  from the hobby store goodies  or   I have used small  fishing swivel snaps .. I just cut-off the  swivel part part and keep the “safety pin” portion of the swivel 🙂      you surely have a few spares  in the tackle box .
            • This reply was modified 4 years, 8 months ago by JACQUES.
