Home › Forum › Ask A Member › Length of fuel line for pressurized OMC tank
  • #299579
    opposedtwin
      I swapped the fuel line in my 6 gallon OMC  pressure tank with a 15 footer so I could move it to the front of my boat to get some ballast. Will the 6 lbs (if i recall correctly) of pressure the crankcase generates be enough to overcome the length of the hose?
      I have run an 8 footer for 10+ years and have never had an issue. Wondering if I’m flirting with disaster here.
      #299580
        distance  does not influence  it   much ……… compared to  how low the tank could  be   which it won’t be anyway.
        jmho
        #299584
          Yes, Crosby man is correct. I had a  1954 Evinrude 15hp pressure tank motor & did the same thing moving it up front. Never had any issues & worked well.
          #299586
          opposedtwin
            Thanks guys!
