Home › Forum › Ask A Member › Length of driveshaft. 1958 Evinrude 10 horsepower.
  • #291169
    William Jatzek
      Hello. Would anybody know the exact lenght for the standard driveshaft for a 1958 Evinrude 10 HP. I have an engine with the leg extension to make the motor longer for a 20” transom. I want to convert it back to a 15” transom motor. Among my circle of friends they have some driveshafts but not having a part number to identify it I am at a loss.  I have picked 3 up from them and they vary by a 1/4 to 1/2” diferent. It has original lower unit. Any help would be appreciated. Excuse some bad spelling here but when I go back to correct words it highlights everything blue and then erases my entire post that I wrote. Regards Bill,
      #291170
      CHUCK
        If you have the powerhead off or would be willing to remove it I think you could tell which of your driveshafts would work.  A good time to remove carbon deposits and have a look around for other issues.
        #291171
        Dale
          Billy you have a hard project you are working on.  The 58 OMC 10hp motors had a lower unit leg similar to the 5 1/2 and the 7 1/2hp on the outside but inside lots of parts were different.  I would suggest you look for a complete 15″ leg.  A couple years ago I built one of these motors and I found a lower unit/leg from this member.   eddelliott@cox.net  Send him a email maybe he can fix you up!
          dale
          #291172
          William Jatzek
            Hello. Yes that was what I was thinking. I am pieceing together a motor from parts. But everything has a part number on it so everything is correct. Exept drive shaft. Lower unit is original to the 1958 leg it just had an exstension added to make the motor for 20” transom. I will have to measure with the powerhead off the leg and see where the shaft sticks up and make sure the shorter 15” shaft sticks up the same. I am aware different year lower units while they may fit as a complete unit have different gear ratio’s and the drive shaft lenght may vary if you mix the parts from lower units that are pieced together. I could possibly jus measure the height of extension and knock off that amount. Thank You. Bill,
            #291173
            William Jatzek
              dale
              Yes. some things take research to find the correct answer. Thank you also.
              #291174
              William Jatzek
                dale
                #291175
                Steve D
                  ’58 10 HP driveshaft length 25-1/2″
                  #291176
                    My Johnson Common Parts List shows the part number for the shorter driveshaft as #305318 if that helps in your search.
                    1982 Evinrude 25hp
                    #291177
                    William Jatzek
                      Thank you. I also got that measurement from a listing on eBay. I also picked up 3 drive shafts from a friend and though identical the lengths varied like a 1/4 ”.  I have another friend that has a 5 gallon bucket of shafts from motors he parted, so I will do a little measuring. The three shafts I got from my friend have some issues where the seal rides. I am going to get one with good surfaces as the motor I pieced together has everything in nice shape.
                      #291178
                      William Jatzek
                           Thanks for the part number. I also like your sayings at the bottom of your message about the broken bolt. I am proud to say I have  achieved with age the humility and wisdom to walk away from a project than to hurry up and break that bolt. Regards Bill,
