Home › Forum › Ask A Member › Leftover Screws: 1957 Evinrude 5½
- This topic has 13 replies, 12 voices, and was last updated 11 years, 5 months ago by
SCOTT MEYER.
May 17, 2015 at 2:05 am #1513
Okay, I replaced the water pump impeller in this motor, which requires removing the powerhead. When I had it all together, I have two screws that don’t have a home (the top two screws in the photo, below; i.e.: the short ones – I know where the other stuff goes). I’m racking my pea brain trying to figure out where they go. Help!
May 17, 2015 at 2:22 am #16168They may be from the vertical shaft that goes from the tiller to mag plate. Holds the guide strips.
RayMay 17, 2015 at 2:38 am #16170quote Ray Schaber:They may be from the vertical shaft that goes from the tiller to mag plate. Holds the guide strips.
RayThanks for the suggestion, but sorry, these are not for the throttle linkage "Control Lever" "Brg Clamps". I kept those two screws partially screwed into their original locations, and that assembly is complete. These two short screws are for something else.
May 17, 2015 at 2:42 am #16171Install new points/condensers with new screws?
Hold-down screws for the strips that hold the plug wires?May 17, 2015 at 2:48 am #16172could those go on the top of the air horns on the carb?
Doug
turned off?May 17, 2015 at 2:55 am #16175The screws that hold the high and low speed stops?
May 17, 2015 at 4:40 am #16183I’m with Doug. If they are not from the throttle’s vertical support bracket, I bet they are from the carb silencer. I just had mine apart last night.
May 17, 2015 at 9:19 am #16192Add me to the "top of the carb silencer" list. Short screws with the lock washers sure look like the vertical screws for the air intake silencer.
May 17, 2015 at 10:39 am #16193I think that Mr Asa is on the right track.
Those are Pan Head screws with ’rounded’ sides and star lockwashers which are common on the armature plate. The only other place that I can think of them is on the starter housing mounts, but those are larger, and there are three of them.
The control arm bracket screws and the air intake/silencer screws are usually Fillister Head screws with the ‘square’ sides.
Improvise-Adapt-Overcome
May 17, 2015 at 11:31 am #16196Sure do look like condenser screws. Or from the clamps & stuff on the bottom of the mag plate. But you didn’t indicate you were into the magneto. Or were you?
