Home › Forum › Ask A Member › lead shots for carbs
  • #3538
    johnyrude200
      So I ran into, yet another, 6hp carb where someone decided to plug the high speed air jet (which is not supposed to be done), causing the motor to flood/run too rich at anything much above idle.
      In the process of pulling the thing apart to make sure there were no other occlusions, I have been trying to think of more cost-effective alternatives than paying $6-9 for a tiny lead shot.
      Has anyone tried just using a fishing line sinker? They’re lead, and they’re small, and I can’t imagine why they wouldn’t work if installed carefully using an oversized punch lined up the right way. And to buy a pack of 50 for $2 seems to make a lot more sense to get the same job done.
      Any other tricks or recommendations?
      #31191
        I confess. I did it. Better yet, melt off a drop of solder and save the sinker for the fish.
        #31192
        johnyrude200
          well, maybe in another 20 years I’ll catch up to the rest of you vets ๐Ÿ˜Ž
          Thanks for confirming I’m not crazy.
          #31196
            I have used solder as well.
            Figured that out when I had to solder a water line up high in my ceiling joists, and I had all the little balls flying down at me due to my poor plumbing skills. Picked a little solder ball out of my neck, and thought hmmmmmmmmmmmm.
            #31197
            Casey Lynn
              Pull the shot from shotgun shells.
              #31198
              wiscoboater
                Try melting some solder about a foot over a bucket of water. Makes perfect little balls when it falls in. Sort of like the old Remington shot towers that made lead shot for shotgun shells, but on a smaller scale ๐Ÿ˜‰
                #31199
                  Epoxy works wonders.
                  #31208
                    you can buy lead shot by the bag at reloading shops… buy the size you want
                    that should fix you up for a couple of generations ๐Ÿ˜†
                    Joining AOMCI has priviledges ๐Ÿ™‚
                    #31213
                    hotrod
                      Solder may not be good. Nowdays it doesn’t contain lead. Lead is soft, which is a desired characteristic for sealing in alumnium carbs. Some solder contains acid for flux purposes. Might cause corrosion in the carb.
                      #31214
                      reivertom
                        Not all shotgun buckshot or birdshot is pure lead. Some of it is a hardened alloy to retain its shape better when shot. If you use shot, make sure the bag says soft or pure lead. Find you a shotshell reloader and get a handful. It will last you the rest of your life.
