Home › Forum › Ask A Member › Lauson T651 Ignition Timing
  • #263922
      Gotta like that drill cord 🙂
      #263923
        It ripped the plug out of the wall, and pulled the drill off the bench
        before I even had a chance to say oops!
        One little nick in the cord, but drill still works okay!
        JOHN D.
          That mark on the coil plate will usually be close. When the points wear the timing changes. I would recommend the 5/32″ to get the proper timing. I have found that the coil will run cooler when the timing is right.
          #264024
            Hope to get back at the Lauson in the next day or two. Have to play “catch up”
            after being away at Tomahawk……. darn grass only takes a vacation in the winter!
              I think I got the timing set okay….. at least it runs.
              Few things to finish, rewind, cowlings, etc.
              Thanks for all the help!
              https://youtu.be/fMqEe0yWY9A
                Yet another one roars to life!   Nice job.
                1982 Evinrude 25hp
                #264080
                JOSEPH BRINCAT
                  Bucc, congratulations … nothing succeeds like success! But careful running without the lower shrouds, they are critical for proper cooling, so it’s said.
                  #264094
                    I’m rarely confident enough that I’m done tinkering with a motor to put the cowls
                    on before the first test start………learned that the hard way, lol.
