Home › Forum › Ask A Member › Lauson Sportking 4 cycle
  • #4521
    1948-goodyear
      I’m trying to help out a man to get the year & hp of this motor ( 11342 ). Any help would be appreciated.
      #38438
        Typical Lauson model numbers are like S350, T653, etc. I can ID it with the correct number.
        #38440
        1948-goodyear
          OK, that was the serial number i gave you. I will go back to his house soon & get the model number, Thanks
          #38459
          JOHN D.
            Could be an OB410. I have a couple of those that don’t have the model number on them. On the front, lower center (oil resivore) , there is a number stamped there. On the S and T models the id plate is located center on transom bracket. On the 410 models, they were produced between 1940 and 1947 excluding the war years.
            #38476
            JOSEPH BRINCAT
              I believe that the last two digits designate the model year …
              " Typical Lauson model numbers are like S350, T653, etc. I can ID it with the correct number"
              #38545
              1948-goodyear
                Ok , the model number is S 350
                #38552
                  I guess by now, we all agree it is a 1950 3hp
                  #38553
                    1948Goodyear
                    Where did you find the model number?
                    Steve A W
                    #38557
                    lotec
                      quote Steve A W:
                      1948Goodyear
                      Steve A W
                      The "S" and "T" series all have the Model and Serial #s on the saddle bracket – here’s a photo:
                      #38559
                      1948-goodyear
                        Yep, it is right above the serial number.
