Home › Forum › Ask A Member › Lauson
  • #287761
    Matthew Pieklik
      I have a Lauson  Sport King Single cylinder that followed me home and I need some direction/suggestions. First off, I cant find a model number anywhere. I have a serial number that was stamped in the rear cowl, or it might be a part number for the cowl . That number is 7082977. I found other numbers on the castings and they were prefixed by an OB. So I think those are part numbers for the pieces. The carb has OB202 and the bowl cover has OB203-1. Has to be a Lauson carb. Looks a little like a Tillotson carb. Either way I think I will be making my own gaskets.  The mounting flange on the carb has a nice bend in it. Looks like someone used a 1/2 inch impact driver to tighten the carb to the block. I would like to straighten it out but I would run the risk of destroying the carb. so I may be going with 2 or 3 mounting gaskets  to fill the gap along with some sealer.        My Questions: Can anyone Identify this motor?  Horse power?    Filling the oil. I’m guessing that I wound fill it till it hits the bottom of the filler hole? And corn head grease for the gear case?  Thanks in advance , Matt.
      IMG_4929
      IMG_4927
      IMG_4932
      #287769
        How about resurfacing the carb flange.  adding gaskets won’t do much. JMHO.
        #287771
          Click on link
          https://www.aomci.org/forums/topic/lauson-motor/
          #287773
            Lauson-Models
