Home › Forum › Ask A Member › L U Shock Absorber
  • #283929
    johng
      What is the Correct Lenth for the 1954′ Johnson 5 1/2 HP Shock  Absorber  located in the Lower Unit  ?
      #283933
        That would be 6-11/16″
        1982 Evinrude 25hp
        #283950
          just tap it down and spot weld it…
          clean any burrs   and run with a shear pin .
          #283951
          Steve Martin
            Make sure it remains true when you weld it.
            #283956
            johng
              Thank you for the reply
              #284007
                You should be able to crush it back to the correct length with a press or big hammer and be good to go. If you do decide to weld it, mounting it in a lathe is best to keep it running true. If welded, the props drive pin will now become a shear pin and should be made of brass or other soft metal. No stainless or monel.
