Home › Forum › Ask A Member › Koban Flywheel
  • #5383
      The ’21 Koban is back on the ‘git er dun’ list but something doesn’t seem quite right with the flywheel.
      Sometime in it’s 95 years, it seems someone has brazed a nut onto the brass flywheel to hold the starter knob shaft. The existing shaft screws into the nut but inside the flywheel I can see where a stud or bolt has been staked with a center punch to hold it in place.
      Would this be the end of the original bolt or screw and would anyone have a picture of an original flywheel?
      Thanks in advance!
      PM T2
        Hope this helps.
        Best,
        PM T2
        #44899
          Yup, that helps a lot Chris!
          So there is a fastener of some kind on the flywheel. The bolt for the knob must screw into it then. Guess I’ll find out for sure when I melt the nut off of mine! Thanks!
          Are those custom heads on your motor?
          #44904
          PM T2
            Stock heads, the 1914-15 Kobans did not have lettering on the cylinder heads. First year for lettering on heads would have been 1916.
            Best,
            PM T2
            #44907
              Thanks, now I know!
