Home › Forum › Ask A Member › KG7 torquing flywheel nut?
  • #1516
    Phil Budne
      What socket or other tool do I need with my torque wrench to tighten the flywheel nut?
      While I’m here what is the correct torque?
      http://www.omc-boats.org
      #16194
      jpatti75
        Here is the official tool, Phil:
        http://store.oldmercs.com/category_s/234.htm
        Correct torque according to the Mercury Master Manual is 60 ft. Lbs.
        JP
        #16270
        richardg
          They also recommend an external star washer under the flywheel nut.
          #16274
          legendre
            quote jpatti75:
            Oh good grief! What ever could have justified that?!
            It looks like it accepts a recoil ratchet gear.. is that what’s going on, here?
            #16280
            jpatti75
              Hahh, funny thing is that I don’t use that tool. Per a very knowledgeable Merc guy around here, I just protect the nut with with a piece of canvas strap and tighten the nut down down good with a monkey wrench. Scientific, nope … but I’ve never had an issue with the couple Mercs I’ve had with that annoying nut.
              As for the nut itself, the recoil pawls engage it when starting the motor. Interesting recoil concept…I’ll leave it at that.
              #16332
              Phil Budne
                Thanks, jpatti, that’s how I got the nut off. How long an adjustable wrench, how many hits with how heavy a hammer?
                #16335
                Phil Budne
                  I’m sure it’s the only KG7 I will ever work on. A tool that price for one short job just does not seem right. All thanks to Karl K. And his wacko ideas, full time genius, part time wacko.
                  #16347
                    Make one flat plate make square for torque wrench 2 holes for boles to line up with flywheel nut.
                    #16348
                    RICHARD A. WHITE
                      I made a tool that will remove both sizes of this wonderful dual purpose flywheel nut..Works well…
                      Drill 9 holes, one pc hex stock of about 5/8 assemble and whallah!
                      classicomctools@gmail.com
                      #16362
                      Phil Budne
                        Thanks, gentlemen!
