Home › Forum › Ask A Member › Kg7 rotation
  • #297643
    Mallett
      Good morning all, looking for a two blade for the kg7. What is the rotation of the prop left or right will a two blade prop make me go faster? Still looking for QS gear box and parts. Any information is helpful. Thanks
      #297652
      John Schubert
        1. Counter clockwise
        #297699
        LLOYD LAUTNER
          I have a KG7 and a bunch of props for it. I think the props are left hand rotation because the water pump cover is removed with a right hand rotation. I learned this many years ago when I replaced the water pump impeller and made the special Mercury tool to remove and replace the water pump cover. I ran the motor many times on my Model R Alumacraft but I can’t remember which prop was fastest. Of course that will depend on the size, weight, and hull design of your boat.
          #297704
          Mallett
            Yeah I should have figured that out myself, for that  exact reason. What prop do you think would be best? I built a Crandall Midget Flyer 10’
            #297725
              #297756
              green-thumbs
                Best prop. boat, motor combination depends on purpose….serious race competitors keep a full rack of alternatives in hopes one might be
                better than the others on a given day, A fits all prop would keep motoer within power band and not lug or overspeed… most users would be ok with that. Mercury warranty was void if motor was used with an unapproved prop… one made by Mercury and listed as
                for that motor. Warranty was not
                all that great… 90 days and
                factory had final say it motor or
                user was at fault. Mercur sold
                speed and performance. Extensive testing at Lake X on various boat
                brands resulted in the Boat House
                Bulletins listing Mercury motor and Mercury propeller combinations suitable for various
                brand and models of boats, A Mercury dealer could sell the complete package with confidence
                he was dong right by the customer.
                Opinion no cash value
                Louis
                #297763
                  Remember: Righty tighty, Lefty lucy Except for the KG WATERPUMP cover, left handed threads so it doesn’t unscrew while running.
                  What app is the mptor used on?
                  #297766
                  Mallett
                    Tub’s thanks, now use the chart to find a prop. Your stuff always looks great, an inspiration.
                    #297767
                    NATHAN KILLIAN
                      US Junior Member
                      A bit off topic, but how long did it take you to build the midget flyer?  I was looking into building one.
                      #297772
                        I have 2 . One was NOS when I got it. They are both mint. I would sell one, but I won’t be back home till around the middle of August if you would be interested.
