Home › Forum › Ask A Member › KG7 Impeller Question
  • #304154
    Aidan Smith
      I have both a KF and KG-7 in my current collection. My KF7 has a standard lower, and my KG7 has a B Quicksilver lower.
      Do these share an impeller? If so, does anyone know who is currently producing them?
      If not, what’s the difference?
      Thanks
      1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
      1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
      #304169
      green-thumbs
        Mercury Parts Catalog shows KF7, KG7 & KG4  use same impeller Part#47  21164
        Non Standard gear cases Q MAY use a different impeller,
        Louis
        #304189
        A. Hoskins
          Green Thumbs is correct and his list should include the KE-7 as well. The quicksilver racing lower units use a (obviously) smaller diameter impeller.
          Certified JB weld
          #304190
          fastjohn
            No.  The KE-7 is different.  It is the same as the KE-4 and Mark 7.  Impellers are available for the KG/Kf-7, or you can use a Sierra 18-3051 or OMC 395289 and reduce the height or thickness.  The other dimensions are the same.
            #304199
            green-thumbs
              KE4/Mark 7 & KE7 have 9/16 prop  shaft
              KF7 KG7 & KG4 have 5/8 prop shaft
              #304213
              A. Hoskins
                Oops, I stand corrected.
                Forgot about the prop shaft diameter.
                I’ve modified the 5/8 I.D. impellers to fit the smaller shaft.
                Certified JB weld
                #304220
                fastjohn
                  Did you use a bushing?  Source?  Picture would help.  Thanks
                  #304222
                    I got one one those impellers and sanded it down but decided not to use it. Those raised portions are meant to make a seal against the cover and inside the cartage so I feel the thickness does matter.  I think I got the thickness OK. The problem I have with this modification is you end up removing all the rubber from the brass center. Now the brass is in contact with the aluminum, no mater way which you face it. I couldn’t come up with a way to remove some of the brass from the center, so I sent a couple of bad impellers to Brian. I take them out while changing the gear lube when I’m done running one of these motors for the season. They’re really easy to get at on these.
                    Impeller-1
                    #304305
                    A. Hoskins
                      Good point. I agree that the raised portions as shown do have a function but I don’t think they are absolutely necessary.
                      When I reduce the section height of the impeller I also cut back the brass center with a Dremel using a bit that kinda looks like a little end mill. It is time consuming. The water pump covers are easy to refinish – the cartridge, not so easy, mostly I don’t bother.
                      The difference between the 5/8′ and 9/16″ shafts is approximately .06″. I use .03″ (same approximation) brass shim stock epoxied in place and cut to clear the pin.
                      Just seems to me that the impeller spinning around in the cartridge at a thousand RPM doesn’t require a real precise fit.
                      Certified JB weld
