Home › Forum › Ask A Member › KG7 Coils
Viewing 11 post (of 11 total)
  • #302841
    Mark Quint
      Hello, I came across this old post as I am having some ignition problems in the bottom cylinder of a KG7… I see that I have only one screw in the back of the magneto assembly. Might that be a problem? I was able to tighten the one that I have to a point that it does not impede throttle movement.  I guess these screws provide compression to the tension springs that prevent the magneto from vibrating. Likely not the cause of my issue, but perhaps I should try to replace the missing one.
