Home › Forum › Ask A Member › KG7 Carb settings
  • #266432
    Jerry Neises
      Can anyone tell me where to start with the AJ32A carburetor settings on my Mercury KG7H?
      I really appreciate any information that you can supply.  Thank you!
      #266433
        1 1/2 turns out from lightly seated. both will get you going. that is what I do.
        • This reply was modified 4 years, 1 month ago by DAVID.
        #266451
          With Dave’s initial settings – gas on – choke on – mag lever
          over to stop – pull the motor over 2 times.
          Push the choke off – move the mag lever to just past center.
          Should start on the first or second pull.
