Home › Forum › Ask A Member › KG4 impeller replacement
  • #4948
    bsplit
      I need to change the impeller on a Mercury KG4. After looking at the parts list, it looks like it’s just forward of the prop and not too difficult to replace. Is there anything special I need to know other than the cover has to be turned clockwise to be removed? Also, where is the best place to purchase the impeller?
      Thanks,
      Jim
      #41790
      brian-grigsby
        I found a NOS impeller on eBay awhile back. Its a pretty easy process as long as the cover comes off. May need to use some heat. The job is much easier using the correct Mercury tool. I tried a spanner type wrench on mine, but couldn’t get enough leverage on it. Good luck…
        #41796
        wedgie
          It was several years ago now, but pretty sure it was Jeff Register who told me to use a short section of pvc pipe ( shaved down on the outside a bit). Clock the impeller into the pipe with some Vaseline and then use the pipe as a guide to get the impeller started into the pump housing. Worked well !
          #41834
          bill-m
            You may have good luck getting a NOS impeller at Seaway Marine. They bought all of mercury’s old shelf stock years ago. I got 2 impellers from them for my KF5 Super 5 last year. If you want to go to the expense of buying a pump housing tool, you can get one from johnmcintosh.com for about $35.00.
            #41889
            bsplit
              Thanks all for the help
              Jim
              #41910
              20mercman
                Big Rich on here sells replacement impellers for that motor also. He is often on the classified section, also Brian Wilcox makes or rebuilds them also. I would prefer a rebuilt one or an aftermarket vs. a NOS one as the last NOS one I had, the blades broke off right away. Time is time…..
                Steve
                #41964
                  My last KG7 impeller came from Old Mercs.Com. Made from urthane of some kind & has worked on the kf5,KE7,KF7 & KG7Been out of touch lately so check my sourses.
                  #42052
                  bsplit
                    I replaced the impeller yesterday, and the motor is pumping water. Apparently the previous owner had the cover off, because it was loose. I made a tool out of a crescent wrench and roll pins. JW in Dixie has posted pictures in the past, and I used his design….Thanks, JW
                    Next impeller replacement will be on a KF7……hopefully it will be similar.
                    Jim
                    #42053
                    Doug Wilson
                      KF7 should be the same set up so your wrench should work great for it too.
                      Doug
                      turned off?
                      #42111
                      bsplit
                        Thanks, dd
