Home › Forum › Ask A Member › KG versus KE7 gas tanks
  • #272361
    CHUCK WEBSTER
      Are these tanks the same dimensions and will interchange with the tanks rims  (i.e. will a KG7 tank rim fit correctly on a KE7 tank?
      #272488
        As you haven’t yet received a response I believe that
        that the KE7 tank has a smaller gas cap & a smaller fuel
        filter but is otherwise the same as the KG7 tank.
        Maybe by moving this back up to the top you will get a
        response from someone that can provide you with a
        more reliable answer.
        #272492
          Yes they will interchange.
          there are 3 size green tanks
          large KG7 type
          medium Mark 7 type
          and small mark 5 type
          some early ones had smaller filters and caps. but will work.
          #272576
          jp53-n
            I have several KE7 and KG7 tanks that I’ll be bringing to Rocky Hill
