Home › Forum › Ask A Member › KG-7 Intake Cover
  • #302068
    Aidan Smith
      Hello!
      Working on a 1951 KG-7 with a Q tower and lower. I’m wondering if there ever was an aftermarket carburetor intake cover or horn, to prevent water intrusion. I have been suggested to modify a ladle or some other round piece of equipment to make a shield, but I wasn’t sure if there was an original piece that could be found. My lower covers do not fit on the motor with the throttle cable installed, so I have to run it as is. If anyone has any other ideas, please let me know.
      Thanks!
      1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
      1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
      #302195
      mercguy
        I don’t think anything like this was ever commercially produced.
        #302208
        green-thumbs
          What you seek may not be a factory standard item or even an accessory. BUT, that should not discourage you from looking
          A hard used KG4 came my way minus cowl, but with an AJ23A carburetor with a combination choke and cover such as you  seek, The screw holes lined up so the cover likely came from a Tillotson carburetor  application without a cowl, Possibly a lawnmower , chainsaw or other  small engine,.
          By all indication the KG4 had been altered for some sort of competition and used quite a bit,
          Hope this helps
          Louis
