Home › Forum › Ask A Member › KF5 Lower unit tool
  • #260997
    huntleybill
      Does anyone make, or can the tool to unscrew the cover/cap in the lower unit be purchased? If so, where?
      I’d like to take a closer look at the gears etc.
      Thank you for your help. Please email me brauscher@sbcglobal.net
      Bill
      #260998
        Make one. use a peice od steel or aluminum drill matching holes in it for prop shaft and hole. put bolts in the holes install tool on cover. add spacers on prop shaft and snug prop nut to hold assy. down. now use tool to loosen the cover Lefthand threads. loosen prop nut when cover loosens.
        #261014
          Not my idea. Was shared on this website.
          I’ve used it on several motors and it works well.
          #261015
          LLOYD LAUTNER
            I made one like the original Mercury Service tool years ago for my KG7.  Works like a charm.  As noted above the threads on the cover are lefthand, so turn Right to loosen cover. If you are near me you are welcome to borrow mine, but I will not sell it.  It will be included with my KG7  with numerous other accessories  that I am selling as a package.
            #261016
            green-thumbs
              When relatively new, a tool (whether a Mercury Service Tool or a work around) could be expected to do the job, If the last person to install the cover lubed the threads that may still be the case. Frequently the cover and gear case threads are corroded together so tightly that force alone will not remove the cover. IF that is your situation, there are several techniques  to loosen the cover, It is not just a matter of squirting some skunk juice elixir…although that may not hurt. Either obtain the required Mercury Service Tool or make a work around tor same purpose, apply your preferred skunk juice to threads and after waiting for penetration. try to turn cover off in clockwise direction…the opposite direction of most threads. If it movers a little…more skunk suice and work the cover back and forth until it comes off, Keep in mind it is a Counter Clock /Wise thread.
              If cover remains stuck, Beat & Heat. Use a hammer and a brass or aluminum rod to tap around the outside of the case over the area of the threads, Use soft metal rods to limit denting the cover. A nylon face hammer might do equally well. This technique shared by Bob Grubb,  Heating the area of gear case over thread to expand the case even a little may help free up threads  Use as much heat as you feel comfortable  with….somewhere between too little and too much. No guarantee of success, but, worth trying.
              If ALL ELSE fails drill and break cover into pieces. Never gone this far, but, some have. Unicast gear case on KF5 thru KG4 share same design plus and minus
              Be sure to clean and lube cover threads prior to assembly and keep in mind cover is NOT screwed on tight.,,friction of impeller prevents cover from backing off.
              Louis
              #261037
                IF you must destroy the cover, I have one.
                that is why i use the propnut method. tool won’t jump out of the cover.
                • This reply was modified 4 years, 5 months ago by DAVID.
                #261042
                huntleybill
                  Thank you all for the good info.
                  #261832
                  Jorzo211
                    There is a company called slipstream cycle that makes old merc tools.
                    MARK-7, KF-7, KE4-A, MARK 15, WN7A, (60)MERC 200
                    #261929
                    CHUCK
                      Thanks for that Jorzo!  Never heard of them!
                      https://slipstreamcycle.com/t/antique-mercury-outboard-service-and-restoration-tools
                      #261934
                      Mallett
                        Just made one out round stock by bending it. Not as nice as Tubs but did the trick.
