Home › Forum › Ask A Member › KE7 Prop shaft Adapter spacer
  • #8334
    mikesea
      Hi Folk’s,
      Anyone sell a cone shaped spacer to close this up on my KE7?
      Thanks,
      Mike 🙂
      #65449
      outboard315
        http://www.ebay.com/itm/11-Spline-Prope … SwuAVWuQio
        Here you go. Ron Hill has them.
        #65450
        mikesea
          Thank you very much I hope I can repay the favor someday.
          Mike
          I see but that one is straight cut on the outside. Looking for a tapered outside I still will toss one on the shelf.
          #65452
          squierka39
            I have the same adapter on my KF-7, I’ve never seen a tapered cover for it. Did anyone ever make such a thing?
            #65459
            20mercman
              That spacer is for the KF-7 and KG-7 with the splined prop shaft. The prop shaft is smooth and smaller on the KE-7. (9/16" vs. 5/8" I think) I can measure them and verify, but I am sure that they are smaller on the KE-7.
              Steve
              #65469
              RICHARD A. WHITE
                As I understand it the originals were in fact 9/16 for the one and 5/8 for the other, but if one changes all the bearings and such they can be used in either. I have a KE7 with a smooth 5/8 prop shaft and a KG7 with a splined shaft…Oh the fun of working on a Merc, but LOVE that speed
                classicomctools@gmail.com
                #65482
                mikesea
                  Hi Richard,
                  Yes,
                  My Merc’s the KE7 has a 5/8 smooth shaft in it and so does my KG4. My first Merc’s and I am enjoying them so much and they never have been run in my hands yet.
                  Mike
                  #65507
                  outboard315
                    So you are looking for an adapter to change from a through shaft shear pin to two parallel pins.
                    #65515
                    mikesea
                      No that is what you see on there now. I am looking for something to compete a smoother contour between the foot and the prop.
                      #65535
                        Nothing I know of is available. From what I have seen with the "exhaust through the hub" lower units, it is unnecessary. The early V4 75 horse used a huge tapered prop nut for a smooth flow of water. No change in performance was found with the use of a smaller nut. The biggest improvement was in prop design. The only way to ensure a smooth transition would be to use a longer prop shaft. Then a transition piece would be more practical.
                        You may be assured that if I am wrong I will quickly be corrected . . .
