Home › Forum › Ask A Member › KE-4 Rocket ?s
Viewing 10 posts - 31 through 40 (of 63 total)
  • #49183
      Glad to pass it on at 70 we need to have the younger guy keep it going.
      #49260
      wyo307
        What is the best way to go about freeing up the vent screw on the gas cap? It seems to be rusted/corroded shut. My thoughts were soak it in something like clr but I didn’t know if that would hurt the plastic gas cap. Any thoughts?
        #49288
          if I have a problem I drill them out and replace them drill small and then use a tap to clean the threads
          #49321
            If you clamp the vent screw in a vice
            between 2 pieces of wood so you don’t
            mar it up then you have more to grab
            on to. Spray with some type of lubricant
            and try just going back and forth at first.
            No luck? Give it a break and try later.
            Time can be a big part of the solution
            when getting stuff unstuck.
            #54410
            wyo307
              Can someone please explain to me how to remove the tower from the transom clamp assembly? The rod circled in the parts diagram needs to come out but I don’t know how it does. It is threaded on the inside of it on the top and there is no hole to take it out the bottom. Any help?
              #54411
              RICHARD A. WHITE
                Thread a 1/2-20 piece of all-thread and pull up and out….
                classicomctools@gmail.com
                #54412
                wyo307
                  Its just pressed in then?
                  #54413
                  mercuryman
                    You can buy replacement coil from Rock Auto for $24.95 – Its Standard #S3-604 made in USA . They work as good as the Phelon.
                    #54419
                    RICHARD A. WHITE
                      quote Wyo307:
                      Yes, but more of a light press, meaning it is not going to require a huge amount of force to get it out..
                      #54426
                        just a slide in fit. a slight tap will do it.
