Home › Forum › Ask A Member › KA 37
  • #291657
    Boonie
      Looking for a connecting rod and piston for a 1937 Johnson KA 37. Possibly piston rings as well. Is this quest even possible given its age. If so where do i start?
      #291659
      ALBERT MOORE
        hang in there i might be able to help. i have a 1936 k80 9.3 hp Johnson . maybe it is the same . I will measure the piston
        and let you know later today.I don’t know how to post pictures . al
        al
        #291660
        GARY
          K50 thru KA38 will work.
          #291681
          ALBERT MOORE
            Boonie
            I have the piston and rod out of the block, the piston measures 2/16 diameter
            the rod and cap is brass there is no play in the wrist pin and there is very little
            scrape marks on side of piston at the wrist pin hole . but in good shape.  there are 2 small rings at bottom
            of piston and  2 rings at near top and 2 rings are missing for the very top . Crank  shaft size is about 7/8 inch
            hope this helps AL
            al
            #291682
            Boonie
              Hey Al
              i think thats what im looking for. I to am having trouble posting pictures. I have done several in the past but now it keeps telling me the file is to big. Not sure how to send a pm either. Somehow we will get hooked up.
              Dan
              #291687
              Boonie
                Where are you located in the US?
                #291688
                ALBERT MOORE
                  contact me at denebm39@outlook.com  Im in Maryland
                  al
