Home › Forum › Ask A Member › KA 37 spark plugs
  • #298753
    Boonie
      I would like to change the spark plugs in my KA 37. They are a two part plug assembly. What do i need to get to replace them. The threaded holes in the cylinders are to large for conventional plugs.
      #298776
      TOM GOEPFRICH
        Spark plugs for that motor are very available. You just need to convert the number on your old plug to the replacement number. I don’i have that info available with me right now. Just post the old plug number here and someone will give the replacement plug number.
        #298779
        Boonie
          Thanks eltoquad. Plugs are Champion R-7.
          #298780
          David Bartlett
            I have used Champion D-9, or NGK A-6 plugs with good results. I have a couple motors with the 2 piece plugs in them and they run just fine. I would rather have an old plug in an old motor.
            David Bartlett
            #298788
            MIKE SIMS
              I have a Champion Spark Plug Chart for 1965 showing replacement for R-7 to be a K-61R
              Champion
              #298790
                Your motor needs a 18mm plug with about 1/2″ reach. Examples would be Champion D-16 & D-17, AC-86. There are other brands as well.
                #298837
                Boonie
                  Went to the local NAPA store and landed on NGK AB-7. Will give them a try.
                  #298838
                  JOSEPH BRINCAT
                    Just a note on the NGK plug coding system … unlike Champion and many other brands the heat code ( last digit) is goes opposite…. the larger the number the colder the plug.
                    I have been having good luck with NGK plugs, I like them
