Home › Forum › Ask A Member › KA 37 powerhead
  • #295185
    Boonie
      Well put my KA 37 power head back together today with new rings. Gave it a spin  with a drill and both cylinders are showing 80 lbs compression.  Acceptable? Still trying to figure out which way the oil slinger is supposed to face?
      #295198
      David Bartlett
        80 PSI should be enough for it to run well. Not sure about the slinger.
        David Bartlett
        #295285
        Boonie
          Can anyone explain how to remove the prop shaft from a KA 37. The drive shaft and prop shaft just dont pull out?
          #295286
            I believe the ball bearing is pressed onto the prop shaft,
            and is a light press into the gear case housing.
            Normally if you heat up the housing and wrap on the
            nose cone with a block of wood, the prop shaft and bearing
            will drop out.
            Boonie
              Thanks Buccaneer. I will try that. Should the drive shaft lift out. Or should the prop shaft come out first. Neither one wants to move?
              #295290
                It looks like the pinion gear is pinned onto the driveshaft,
                and I’m thinking the driveshaft would have to come out first,
                after you remove the pin.
                KA37
                Boonie
                  Hey Buccaneer i think you mean the prop shaft would have to come out first?
                  #295307
                  Boonie
                    So on the KA 37 without a water pump/impeller how does the cooling system work?
                    #295317
                    Boonie
                      Found my answers on an older post.
                      #295320
                         If you haven discovered how to get the gear off the drive shaft, there is a spring ring that covers this pin. It is a real PITA to get off.
                        J-Pin-180
